주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5576 Gaming Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Disconnecting the Hard Drive Cable: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Lifting the Hard Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Disconnect the Interposer: 4 단계, 이미지 1개 중 1개
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Hard Drive Bracket: 6 단계, 이미지 1개 중 1개
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Align the Screw Holes: 7 단계, 이미지 1개 중 1개
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  8. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Replace the Screws: 8 단계, 이미지 1개 중 1개
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Connect the Interposer: 9 단계, 이미지 1개 중 1개
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Align the Screw Holes: 10 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Replace the Screws: 11 단계, 이미지 1개 중 1개
    • Replace the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Connect the Hard Drive Cable: 12 단계, 이미지 1개 중 1개
    • Connect the hard-drive cable to the connector on the system board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 664
