주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5577 Gaming Battery Replacement
필요한 것
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Remove the Battery Cable: 1 단계, 이미지 1/1
  2. Dell Inspiron 15 5577 Gaming Battery Replacement, Remove the Screws: 2 단계, 이미지 1/1
    • Remove the five screws (M2x5 T8) that secure the battery to the computer base.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement, Lifting the Battery: 3 단계, 이미지 1/1
    • Using the pull tab, lift the battery, along with its cable, off the computer base.
    • Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement, Sliding the Battery: 5 단계, 이미지 1/1
    • Slide the NEW battery in the slot on the computer base.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement, Align the Screw Holes: 6 단계, 이미지 1/1
    • Align the screw holes on the battery with the screw holes on the computer base.
  6. Dell Inspiron 15 5577 Gaming Battery Replacement, Replace the Screws: 7 단계, 이미지 1/1
    • Replace the five screws (M2x5 T8) that secure the battery to the computer base.
  7. Dell Inspiron 15 5577 Gaming Battery Replacement, Routing the Battery Cable: 8 단계, 이미지 1/1
    • Route the battery cable through the routing guides on the computer base.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,131 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,986개 작성하였습니다
댓글 한 개
Please include a screwdriver valid for the M2x5 T8 battery screws under tools. Thanks.
David Paul Hamilton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 4,896
