소개
In this guide, we will be showing you how to remove and replace the Battery.
필요한 것
Remove the battery cable from the routing guides on the computer base.
Remove the five screws (M2x5 T8) that secure the battery to the computer base.
Using the pull tab, lift the battery, along with its cable, off the computer base.
Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the five screws (M2x5 T8) that secure the battery to the computer base.
Route the battery cable through the routing guides on the computer base.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Please include a screwdriver valid for the M2x5 T8 battery screws under tools. Thanks.
