주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5577 Gaming Fans Replacement
필요한 것
  1. Dell Inspiron 15 5577 Gaming Fans Replacement, Fans: 1 단계, 이미지 1/1
    • Unscrew the base cover plate to locate the gaming fan.
  2. Dell Inspiron 15 5577 Gaming Fans Replacement: 2 단계, 이미지 1/1
    • Remove the base cover.
  3. Dell Inspiron 15 5577 Gaming Fans Replacement: 3 단계, 이미지 1/1
    • Gently tug on the battery cable in order to disconnect it from the motherboard.
  4. Dell Inspiron 15 5577 Gaming Fans Replacement: 4 단계, 이미지 1/1
    • Loosen the screws that secure the battery in place.
  5. Dell Inspiron 15 5577 Gaming Fans Replacement: 5 단계, 이미지 1/1
    • Carefully pull the battery out of the laptop.
  6. Dell Inspiron 15 5577 Gaming Fans Replacement: 6 단계, 이미지 1/1
    • Remove the cable above the hard drive.
  7. Dell Inspiron 15 5577 Gaming Fans Replacement: 7 단계, 이미지 1/1
    • Loosen the screws that secure the hard drive.
  8. Dell Inspiron 15 5577 Gaming Fans Replacement: 8 단계, 이미지 1/1
    • Carefully remove the hard drive.
  9. Dell Inspiron 15 5577 Gaming Fans Replacement: 9 단계, 이미지 1/3 Dell Inspiron 15 5577 Gaming Fans Replacement: 9 단계, 이미지 2/3 Dell Inspiron 15 5577 Gaming Fans Replacement: 9 단계, 이미지 3/3
    • Flip the laptop over and open the lid.
    • Remove the palm rest.
  10. Dell Inspiron 15 5577 Gaming Fans Replacement: 10 단계, 이미지 1/1
    • Carefully unsecure the rest of the shell on the base of the computer.
  11. Dell Inspiron 15 5577 Gaming Fans Replacement: 11 단계, 이미지 1/1
    • Remove the keyboard.
  12. Dell Inspiron 15 5577 Gaming Fans Replacement: 12 단계, 이미지 1/1
    • Loosen the screws securing the metal plate and contents of the base.
  13. Dell Inspiron 15 5577 Gaming Fans Replacement: 13 단계, 이미지 1/1
    • Remove the plate.
  14. Dell Inspiron 15 5577 Gaming Fans Replacement: 14 단계, 이미지 1/1
    • Unscrew and remove the first fan from the base of the laptop.
  15. Dell Inspiron 15 5577 Gaming Fans Replacement: 15 단계, 이미지 1/1
    • Remove the fan's cable from the board.
  16. Dell Inspiron 15 5577 Gaming Fans Replacement: 16 단계, 이미지 1/1
    • Repeat steps 14 and 15 for the remaining fan.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Julia Cabral
회원 가입일: 10/31/19
379 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G7, Barthe Fall 2019 UMass Dartmouth, Team S2-G7, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G7
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 40
전체 시간: 2,121
