주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
필요한 것
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: 1 단계, 이미지 1/1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 2 단계, 이미지 1/1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 3 단계, 이미지 1/1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 4 단계, 이미지 1/1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 5 단계, 이미지 1/1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 6 단계, 이미지 1/1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 7 단계, 이미지 1/1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
결론
[deleted]
회원 가입일: 10/31/19
346 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 733
