주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5577 Gaming Laptop RAM Replacement
필요한 것
  1. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement, RAM: 1 단계, 이미지 1/2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Before working inside your laptop, read the safety information that came with the laptop and follow the steps "When Working Inside Your Device."
    • Shut down the device by holding down the power button for a few seconds.
    • Remove the power cable from the device.
  2. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 2 단계, 이미지 3/3
    • Flip the device over so that the bottom is facing up.
    • With a Phillips #00 screwdriver, loosen the screw located at the top of the base panel.
    • Loosen the screw so that it is removed from the insert but is still connected to the base panel. This will create an opening for the next step.
  3. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 3 단계, 이미지 3/3
    • Use a spudger to gently pry up the top of the base panel until it pops loose.
    • Continue along the edges.
    • The corners may require a bit more force to pop loose, but refrain from applying excessive force.
  4. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 4 단계, 이미지 2/2
    • Remove the laptop base panel.
  5. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 5 단계, 이미지 1/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 5 단계, 이미지 2/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 5 단계, 이미지 3/3
    • Use your fingertips to spread apart the securing-clips on both ends of the slot until the RAM stick pops up.
    • Remove the RAM stick.
  6. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 6 단계, 이미지 1/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 6 단계, 이미지 2/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 6 단계, 이미지 3/3
    • Align the notch of the new RAM stick with the tab in the slot.
    • Firmly slide the new RAM in the slot at an angle.
    • Press down until both secure-clips click into place.
    • If you do not hear the click, remove and reinstall the RAM stick again.
  7. Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 7 단계, 이미지 1/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 7 단계, 이미지 2/3 Dell Inspiron 15 5577 Gaming Laptop RAM Replacement: 7 단계, 이미지 3/3
    • Replace the base panel.
    • Firmly press on the edges of the base panel until it is clicked in.
    • Tighten the screw at the top of the base panel.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
John Lacadin
회원 가입일: 09/17/20
172 평판
안내서 1개 작성함
York University, Team S2-G10, Melo-Thaiss Spring 2020 York University, Team S2-G10, Melo-Thaiss Spring 2020 회원
YORK-MELO-THAISS-S20S2G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 38
전체 시간: 1,134
