소개
In this guide, we will be showing you how to remove and replace the Memory Modules.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
거의 끝나갑니다!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
