주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Open the Display: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Placing the Computer Down: 2 단계, 이미지 1개 중 1개
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Remove the Screws: 3 단계, 이미지 1개 중 1개
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Remove the Antenna Cables: 4 단계, 이미지 1개 중 1개
    • Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: 5 단계, 이미지 1개 중 1개
    • Lift the display assembly off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Align the Screw Holes: 6 단계, 이미지 1개 중 1개
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  7. Dell Inspiron 15 5578 2-in-1 Display Assembly Replacement, Replace the Screws: 7 단계, 이미지 1개 중 1개
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Turn the computer over and close the display.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,522 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 16
전체 시간: 2,016
