주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Hard Drive Cable: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Hard Drive Cable: 1 단계, 이미지 2개 중 2개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Peel off the Tape: 2 단계, 이미지 1개 중 1개
    • Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
  3. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Noting the Hard Drive Cable: 3 단계, 이미지 1개 중 1개
    • Note the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 5 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  6. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Interposer: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Disconnect the Interposer: 6 단계, 이미지 2개 중 2개
    • Disconnect the interposer from the hard-drive assembly.
  7. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Remove the Screws: 7 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Lifting the Hard Drive: 8 단계, 이미지 2개 중 1개 Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Lifting the Hard Drive: 8 단계, 이미지 2개 중 2개
    • Lift the hard drive off the hard-drive bracket.
  9. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Align the Screw Holes: 9 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  10. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Replace the Screws: 10 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  11. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Connecting the Interposer: 11 단계, 이미지 1개 중 1개
    • Connect the interposer to the hard-drive assembly.
  12. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Align the Screw Holes: 12 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  13. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Replace the Screws: 13 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  14. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Routing the Hard Drive Cable: 14 단계, 이미지 1개 중 1개
    • Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
  15. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Connect the Hard Drive Cable: 15 단계, 이미지 1개 중 1개
    • Connect the hard-drive cable to the system board.
  16. Dell Inspiron 15 5578 2-in-1 Hard Drive Replacement, Adhering the Tape: 16 단계, 이미지 1개 중 1개
    • Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 1,259
