주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5584 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15 5584 Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Hard Drive Replacement, Battery: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift up the motherboard ribbon latch using a pair of tweezers.
    • Gently lift the ribbon cable from the motherboard connector socket.
    • Pulling out the ribbon cable too quickly can damage the connector.
  8. Dell Inspiron 15 5584 Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 3 mm hard drive cover screws using a JIS #0 screwdriver.
  9. Dell Inspiron 15 5584 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the hard drive cover plate from the device.
    • Unplug the connector cable from the hard drive.
    • Remove the hard drive from the device and place it safely to the side.
결론
작성자
4다른 기여자 명과 함께
Sam Vorn
회원 가입일: 03/29/22
977 평판
안내서 9개를 작성함
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S1G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 16
전체 시간: 537
