주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5584 Wi-Fi Card Replacement
필요한 것
  1. Dell Inspiron 15 5584 Wi-Fi Card Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 5584 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 3개 중 1개 Dell Inspiron 15 5584 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 3개 중 2개 Dell Inspiron 15 5584 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 3개 중 3개
    • Remove the single 3 mm screw that holds down the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
92,176 평판
안내서 241개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,470개를 작성함
댓글 한 개
The problem isn't taking the card out. It's putting it in and especially attaching the micro connectors to the card without messing them up. This is a poor design which literally requires a electron microscope to see what your doing. I would like ot know how one does this and with what tools.
SCWD - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 12
전체 시간: 152
