주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Turn the Computer Over: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Place the Computer: 2 단계, 이미지 1/1
    • Place the computer on a flat surface with the display facing down.
  3. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Remove the Screws: 3 단계, 이미지 1/1
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  4. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Lifting the Display Assembly: 4 단계, 이미지 1/1
    • Lift the display assembly off the palm-rest assembly.
  5. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Align the Screw Holes: 5 단계, 이미지 1/1
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  6. Dell Inspiron 15 7579 2-in-1 Display Assembly Replacement, Replace the Screws: 6 단계, 이미지 1/1
    • Replace the screws that secure the NEW display assembly to the palm-rest assembly.
    • Turn the computer over and close the display.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 1,700
