소개
If your Dell Inspiron 15 7579 is having issues with the display such as flickering, monitor ghosting, or any other issue concerning the display of the laptop, this guide will walk you through step by step to help fix your laptop. This guide will require you to remove other parts of the laptop before you can remove the display.
필요한 것
Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
Remove the screw that holds the Wi-Fi card in place with a Phillips #0 screwdriver.
Disconnect the black and white coaxial cables from the Wi-Fi card.
Remove the Wi-Fi card from its port.
