주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7579 Display Replacement
필요한 것
  1. Dell Inspiron 15 7579 Display Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Display Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement: 2 단계, 이미지 2/2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Display Replacement, Fan: 3 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Display Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement: 4 단계, 이미지 2/2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Display Replacement: 5 단계, 이미지 1/1
    • Carefully lift the fan out of the computer.
  6. Dell Inspiron 15 7579 Display Replacement, SSD M.2 Drive: 6 단계, 이미지 1/1
    • Remove the single 3.6 mm screw holding the left side of the M.2 SSD card with a Phillips PH0 screwdriver.
  7. Dell Inspiron 15 7579 Display Replacement: 7 단계, 이미지 1/1
    • Gently pull out the SSD card at the angle it is relaxed in to remove it. It is easiest to do this by hand.
    • Be gentle when pulling the SSD card out. It should take little effort to get it to slide out properly.
  8. Dell Inspiron 15 7579 Display Replacement, Motherboard: 8 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement, Motherboard: 8 단계, 이미지 2/2
    • Remove the six 2.1 mm screws with the Phillips #0 screwdriver.
  9. Dell Inspiron 15 7579 Display Replacement: 9 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement: 9 단계, 이미지 2/2
    • Unplug the eight ribbon cables connected to the motherboard.
  10. Dell Inspiron 15 7579 Display Replacement: 10 단계, 이미지 1/1
    • Lift the motherboard up from the side opposite of the external ports and remove it from the laptop.
  11. Dell Inspiron 15 7579 Display Replacement, Display: 11 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement, Display: 11 단계, 이미지 2/2
    • Remove the screw that holds the Wi-Fi card in place with a Phillips #0 screwdriver.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
    • Remove the Wi-Fi card from its port.
  12. Dell Inspiron 15 7579 Display Replacement: 12 단계, 이미지 1/2 Dell Inspiron 15 7579 Display Replacement: 12 단계, 이미지 2/2
    • Remove the two screws from the metal plates with the Phillips #0 screwdriver.
  13. Dell Inspiron 15 7579 Display Replacement: 13 단계, 이미지 1/3 Dell Inspiron 15 7579 Display Replacement: 13 단계, 이미지 2/3 Dell Inspiron 15 7579 Display Replacement: 13 단계, 이미지 3/3
    • Lift up the two hinges perpendicularly to the board beneath it.
    • It may be difficult to lift up the hinges, so it may take some force to remove them.
    • Lift up on the keyboard at an angle from the laptop and gently pull away from hinges.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 34
전체 시간: 1,106
