주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7579 Fan Replacement
필요한 것
  1. Dell Inspiron 15 7579 Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15 7579 Fan Replacement: 2 단계, 이미지 2/2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Fan Replacement, Fan: 3 단계, 이미지 1/2 Dell Inspiron 15 7579 Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the two 7.9 mm screws from the fan with a Phillips #0 screwdriver.
  4. Dell Inspiron 15 7579 Fan Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15 7579 Fan Replacement: 4 단계, 이미지 2/2
    • Unplug the wires from the port.
    • Be sure to pull from the plastic connector, not the wires.
  5. Dell Inspiron 15 7579 Fan Replacement: 5 단계, 이미지 1/1
    • Carefully lift the fan out of the computer.
결론
Richard Parker
회원 가입일: 09/20/21
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 225
