주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7579 RAM (Memory) Replacement
필요한 것
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15 7579 RAM (Memory) Replacement: 2 단계, 이미지 2/2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): 3 단계, 이미지 1/1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: 4 단계, 이미지 1/3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 4 단계, 이미지 2/3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: 5 단계, 이미지 1/3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 5 단계, 이미지 2/3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 5 단계, 이미지 3/3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: 6 단계, 이미지 1/2 Dell Inspiron 15 7579 RAM (Memory) Replacement: 6 단계, 이미지 2/2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
결론
Inaki Madrigal
회원 가입일: 04/23/18
760 평판
안내서 6개 작성하였습니다
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 회원
CPSU-MANESS-S18S24G9
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 711
