주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7579 Wifi Card Replacement
필요한 것
  1. Dell Inspiron 15 7579 Wifi Card Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Wifi Card Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15 7579 Wifi Card Replacement: 2 단계, 이미지 2/2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Wifi Card Replacement, Wifi Card: 3 단계, 이미지 1/1
    • Remove the bracket holding the card in place by unscrewing the single 3 mm screw located in the upper left hand corner of the device using a Phillips #1 screwdriver bit.
  4. Dell Inspiron 15 7579 Wifi Card Replacement: 4 단계, 이미지 1/1
    • Pull the Wi-Fi card out of the connector slot.
  5. Dell Inspiron 15 7579 Wifi Card Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the two connector pins from the wifi card using tweezers.
    • During reassembly, the pins require some finesse to fit them back onto the card. It will take time to put back on. Be sure to line up the socket on the cable to the pin socket on the card.
결론
Inaki Madrigal
회원 가입일: 04/23/18
745 평판
안내서 6개 작성하였습니다
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 회원
CPSU-MANESS-S18S24G9
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 3,764
