주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7591 2-in-1 Battery Replacement
필요한 것
  1. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Opening the Laptop: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 7591 2-in-1 Battery Replacement, Opening the Laptop: 1 단계, 이미지 2개 중 2개
    • Unscrew the 7 Philips #000 screws.
    • Loosen the 2 Philips #000 screws. These screws do not come out but rather stay attached to the case.
    • With a suction cup lift the top and insert a plastic pry tool or guitar pick. Slide the pry tool from left to right. The panel should pop out slightly.
    • Work downwards with a pry tool on the right and left sides. The panel should pop up and be able to be removed.
  2. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Remove the 2 Philips #000 screws.
    • Loosen the Philips #000 screws. The screw is attached to the battery and will remain attached to the battery.
  3. Dell Inspiron 15 7591 2-in-1 Battery Replacement, Disconnecting the Battery: 3 단계, 이미지 1개 중 1개
    • Flip the battery upside down onto the motherboard.
    • Snake the wire out of its housing.
    • Disconnect the power connector.
  4. Dell Inspiron 15 7591 2-in-1 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the battery in with the bottom first in order to attach the latches that are at the bottom.
    • Screw in the 2 Phillips #000 screws and tighten the 1 Phillips #000 screw attached to the battery.
결론
To reassemble your device, follow these instructions in reverse order. When re-attaching the bottom panel be careful when tightening the screws near the trackpad. If these screws are over tightened it can prevent the trackpad from being clicked.
작성자
2다른 기여자 명과 함께
Griffin Nott
회원 가입일: 04/29/22
181 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 47
전체 시간: 1,256
