주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7591 2-in-1 Trackpad Replacement
필요한 것
  1. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Opening the Laptop: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Opening the Laptop: 1 단계, 이미지 2개 중 2개
    • Unscrew the 7 Philips #000 screws.
    • Loosen the 2 Philips #000 screws. These screws do not come out but rather stay attached to the case.
    • With a suction cup lift the top and insert a plastic pry tool or guitar pick. Slide the pry tool from left to right. The panel should pop out slightly.
    • Work downwards with a pry tool on the right and left sides. The panel should pop up and be able to be removed.
  2. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Remove the 2 Philips #000 screws.
    • Loosen the Philips #000 screws. The screw is attached to the battery and will remain attached to the battery.
  3. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Disconnecting the Battery: 3 단계, 이미지 1개 중 1개
    • Flip the battery upside down onto the motherboard.
    • Snake the wire out of its housing.
    • Disconnect the power connector.
  4. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the battery in with the bottom first in order to attach the latches that are at the bottom.
    • Screw in the 2 Phillips #000 screws and tighten the 1 Phillips #000 screw attached to the battery.
  5. Dell Inspiron 15 7591 2-in-1 Trackpad Replacement, Removing the Trackpad: 5 단계, 이미지 1개 중 1개
    • After removing the battery in step 3 the track-pad is exposed.
    • Remove the 5 Phillips #000 screws.
    • Disconnect the blue ribbon connector.
결론
작성자
1다른 기여자 명과 함께
Griffin Nott
회원 가입일: 04/29/22
181 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 375
