주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Gaming 7566 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Lifting the Latch: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
    • Using a plastic scribe, lift the latch and use the pull tab to disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Remove the Screws: 2 단계, 이미지 1/1
    • Remove the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Lifting the Hard Drive Assembly: 3 단계, 이미지 1/1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Disconnect the Interposer: 4 단계, 이미지 1/1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Remove the Screws: 5 단계, 이미지 1/1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Align the Screw Holes: 6 단계, 이미지 1/1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Replace the Screws: 7 단계, 이미지 1/1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive
  8. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Connect the Interposer: 8 단계, 이미지 1/1
    • Connect the interposer to the hard-drive assembly.
  9. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Align the Screw Holes: 9 단계, 이미지 1/1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  10. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Replace the Screws: 10 단계, 이미지 1/1
    • Replace the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  11. Dell Inspiron 15 Gaming 7566 Hard Drive Replacement, Connecting the Hard Drive Cable: 11 단계, 이미지 1/1
    • Connect the hard-drive cable to the system board and close the latch to secure the hard-drive cable.
결승점
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 701
