주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Gaming 7567 Battery Replacement
필요한 것
  1. Dell Inspiron 15 Gaming 7567 Battery Replacement, Remove the Battery Cable: 1 단계, 이미지 1/1
  2. Dell Inspiron 15 Gaming 7567 Battery Replacement, Remove the Screws: 2 단계, 이미지 1/1
    • Remove the five screws (M2x4 T8) that secure the battery to the computer base.
  3. Dell Inspiron 15 Gaming 7567 Battery Replacement, Lifting the Battery: 3 단계, 이미지 1/1
    • Lift the battery at an angle off the computer base.
    • Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 15 Gaming 7567 Battery Replacement, Sliding the Battery: 5 단계, 이미지 1/1
    • Slide the battery in the slot on the computer base and align the screw holes on the battery with the screw holes on the computer base.
  5. Dell Inspiron 15 Gaming 7567 Battery Replacement, Replace the Screws: 6 단계, 이미지 1/1
    • Replace the five screws (M2x4 T8) that secure the battery to the computer base.
  6. Dell Inspiron 15 Gaming 7567 Battery Replacement, Routing the Battery Cable: 7 단계, 이미지 1/1
    • Route the battery cable through the routing guides on the computer base.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 한 개
Dell UK do not sell a genuine battery replacement (part 71JF4). Where can a battery be purchased that will work, without running into the issue stated on the Dell forum that non-Dell batteries are not recognised and will not charge? Replacement batteries shown on Amazon and eBay provide no certainty that they are genuine or would otherwise work. Thanks!
Saskwoch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 34
전체 시간: 3,844
