주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Gaming 7567 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Disconnect the Camera Cable: 1 단계, 이미지 1/1
  2. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Peeling the Camera Cable: 2 단계, 이미지 1/1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Note the Routing: 3 단계, 이미지 1/1
    • Note the antenna cables routing and remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screw: 4 단계, 이미지 1/1
    • Remove the screw (M3x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Lifting the Display Cable: 5 단계, 이미지 1/1
    • Lift the display-cable bracket off the computer base.
  6. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Disconnecting the Display Cable: 6 단계, 이미지 1/1
    • Using the pull tab, disconnect the display cable from the system board.
  7. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Display Cable: 7 단계, 이미지 1/1
    • Remove the display cable from the routing guides on the computer base and peel off the display cable from the computer base.
  8. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screws: 8 단계, 이미지 1/1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screws: 9 단계, 이미지 1/1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Open the Display: 10 단계, 이미지 1/1
    • Turn the computer over and open the display.
  11. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Remove the Screws: 11 단계, 이미지 1/1
  12. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Lifting the Display Assembly: 12 단계, 이미지 1/1
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Align the Screw Holes: 13 단계, 이미지 1/1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screws: 14 단계, 이미지 1/1
    • Replace the two screws (M2x2.5) that secure the display assembly to the computer base.
  15. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Close the Display: 15 단계, 이미지 1/1
    • Close the display and turn the computer over.
  16. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screws: 16 단계, 이미지 1/1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screws: 17 단계, 이미지 1/1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  18. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Route the Display Cable: 18 단계, 이미지 1/1
    • Route the display cable through the routing guides on the computer base.
  19. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Adhering the Display Cable: 19 단계, 이미지 1/1
    • Adhere the display cable and the camera cable to the computer base.
  20. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Connect the Display Cable: 20 단계, 이미지 1/1
    • Connect the display cable to the system board.
  21. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Align the Screw Hole: 21 단계, 이미지 1/1
    • Align the screw hole on display-cable bracket with the screw hole on the computer base.
  22. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Replace the Screw: 22 단계, 이미지 1/1
    • Replace the screw (M3x3) that secures the display-cable bracket to the computer base.
  23. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Route the Antenna Cables: 23 단계, 이미지 1/1
    • Route the antenna cables through the routing guides on the computer base.
  24. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Adhering the Camera Cable: 24 단계, 이미지 1/1
    • Adhere the camera cable to the computer base.
  25. Dell Inspiron 15 Gaming 7567 Display Assembly Replacement, Connecting the Camera Cable: 25 단계, 이미지 1/1
    • Connect the camera cable to the system board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 2개
i bought the version with the tn panel, is there a list of compatible ips panels for this particular model? thanks
michael gunawan - 답글
Hello, I bought an IPS version around a year ago but in that time a number of things happened, The computer goes to sleep without the lid being down, so i changed the setting to “Do nothing” when i closed the lid. As you expect it did not help, insead of going to sleep the display goes black, Also my ASDFJKL keys dont work, they work somethimes but im typing on a wired keyboard because of it. I NEED HELP PLEASE HELP
Dereck Scott - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 3,114
