주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement
필요한 것
  1. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: 1 단계, 이미지 1/2 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement, M.2 NVMe Solid State Drive: 1 단계, 이미지 2/2
    • Place the laptop with the bottom panel facing up.
    • Remove the single screw to access the bottom panel.
  2. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 2 단계, 이미지 3/3
    • Place a finger under the screw location and move it around the edge to pry the fourteen clips out.
    • There are six clips on each side of the panel and two on the edge by the screw.
    • Remove the bottom panel.
  3. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 3 단계, 이미지 3/3
    • Locate the M.2 drive to the right of the battery, below the hard drive.
    • Remove the screw on the edge of the drive.
  4. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 4 단계, 이미지 1/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 4 단계, 이미지 2/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 4 단계, 이미지 3/3
    • Lift up on the edge of the drive where the screw was.
    • Grab the drive by the two long edges.
    • Pull the drive out.
    • Note the keying on your new drive; it will only go in one way.
  5. Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 5 단계, 이미지 1/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 5 단계, 이미지 2/3 Dell Inspiron 15 Gaming 7577 M.2 NVMe Drive Replacement: 5 단계, 이미지 3/3
    • Angle the new drive and insert it into the slot.
    • Apply pressure down on the screw end of the drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kevin Day
회원 가입일: 01/16/20
160 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 36
전체 시간: 3,082
