주요 콘텐츠로 건너뛰기
Dell Inspiron 15 M5030 Battery Replacement
  1. Dell Inspiron 15 M5030 Battery Replacement, Turn over the Computer: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Shut down the computer and turn it over.
  2. Dell Inspiron 15 M5030 Battery Replacement, Sliding the Lock Latch: 2 단계, 이미지 1개 중 1개
    • Slide the battery lock latch to the unlock position.
  3. Dell Inspiron 15 M5030 Battery Replacement, Sliding the Battery Latch: 3 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the side.
  4. Dell Inspiron 15 M5030 Battery Replacement, Lifting the Battery: 4 단계, 이미지 1개 중 1개
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron 15 M5030 Battery Replacement, Align the Tabs: 5 단계, 이미지 1개 중 1개
    • Align the tabs on the NEW battery with the slots on the battery bay.
  6. Dell Inspiron 15 M5030 Battery Replacement, Sliding the Battery: 6 단계, 이미지 1개 중 1개
    • Slide the battery into the battery bay until it clicks into place.
  7. Dell Inspiron 15 M5030 Battery Replacement, Sliding the Battery Lock Latch: 7 단계, 이미지 1개 중 1개
    • Slide the battery lock latch to the lock position.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 170
