주요 콘텐츠로 건너뛰기
Dell Inspiron 15 M5030 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15 M5030 Hard Drive Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard drive to the base of the computer.
  2. Dell Inspiron 15 M5030 Hard Drive Replacement, Sliding the Hard Drive: 2 단계, 이미지 1개 중 1개
    • Slide the hard drive away from the hard-drive connector on the system board.
  3. Dell Inspiron 15 M5030 Hard Drive Replacement, Lifting the Hard Drive: 3 단계, 이미지 1개 중 1개
    • Lift the hard drive out of the hard-drive bay.
  4. Dell Inspiron 15 M5030 Hard Drive Replacement, Placing the Hard Drive: 4 단계, 이미지 1개 중 1개
    • Place the NEW hard drive in the hard-drive bay and push the hard drive towards the connector until it is fully seated.
  5. Dell Inspiron 15 M5030 Hard Drive Replacement, Replace the Screws: 5 단계, 이미지 1개 중 1개
    • Turn the computer over and replace the two screws that secure the hard- drive to the base of the computer.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 262
