주요 콘텐츠로 건너뛰기
Dell Inspiron 15 M5030 Memory Modules Replacement
  1. Dell Inspiron 15 M5030 Memory Modules Replacement, Popping up the Memory Module: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
  2. Dell Inspiron 15 M5030 Memory Modules Replacement, Remove the Memory Module: 2 단계, 이미지 1개 중 1개
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 15 M5030 Memory Modules Replacement, Align the Notch: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 M5030 Memory Modules Replacement, Align the Notch: 3 단계, 이미지 2개 중 2개
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron 15 M5030 Memory Modules Replacement, Sliding the Memory Module: 4 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 76
