주요 콘텐츠로 건너뛰기
Dell Inspiron 15 N5040 Battery Replacement
  1. Dell Inspiron 15 N5040 Battery Replacement, Turn off the Computer: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
  2. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery Latch: 2 단계, 이미지 1/1
    • Slide the battery lock latch to the unlock position until it clicks into place.
  3. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Latch: 3 단계, 이미지 1/1
    • Slide and hold the battery release latch in the unlock position.
  4. Dell Inspiron 15 N5040 Battery Replacement, Removing the Battery: 4 단계, 이미지 1/1
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery: 5 단계, 이미지 1/1
    • Slide the NEW battery into the battery bay until it clicks into place.
  6. Dell Inspiron 15 N5040 Battery Replacement, Sliding the Battery Latch: 6 단계, 이미지 1/1
    • Slide the battery lock latch to the lock position.
결승점
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 266
