주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Optical Drive Replacement
필요한 것
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 15 Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 2/2
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Edward Pacheco
회원 가입일: 03/06/16
833 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 28
전체 시간: 4,682
