주요 콘텐츠로 건너뛰기
Dell Inspiron 15 Ram (Memory Module) Replacement
필요한 것
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 3 단계, 이미지 3개 중 1개 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 3 단계, 이미지 3개 중 2개 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 3 단계, 이미지 3개 중 3개
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 15 Ram (Memory Module) Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 15 Ram (Memory Module) Replacement: 4 단계, 이미지 3개 중 3개
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Edward Pacheco
회원 가입일: 03/06/16
852 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 29
전체 시간: 7,114
