주요 콘텐츠로 건너뛰기
Dell Inspiron 15-3521 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 1 단계, 이미지 1/3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 1 단계, 이미지 2/3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Battery: 1 단계, 이미지 3/3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 2 단계, 이미지 1/3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 2 단계, 이미지 2/3 Dell Inspiron 15-3521 Hard Drive Replacement, Removing the Access Panel: 2 단계, 이미지 3/3
    • Loosen the two screws attaching the access door to the laptop body.
    • Using a spudger, pry open the access door from the laptop.
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 3 단계, 이미지 1/3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 3 단계, 이미지 2/3 Dell Inspiron 15-3521 Hard Drive Replacement, Remove the Hard Drive: 3 단계, 이미지 3/3
    • Locate the two hard drive screws, located on the left-hand side of the hard drive casing.
    • Loosen and remove these screws using a phillips head screw driver PH0.
    • Push the hard drive to the left, and then lift out of the laptop casing to remove from laptop.
  4. Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 4 단계, 이미지 1/3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 4 단계, 이미지 2/3 Dell Inspiron 15-3521 Hard Drive Replacement, Accessing Hard Drive: 4 단계, 이미지 3/3
    • Identify the Hard Drive caddy screws, one on each side of the hard drive casing.
    • Remove these screws using a phillips head PH0 screwdriver.
    • Now, with a new hard drive, attach the caddy/casing using the same screws removed from the old hard drive.
결론
다른 27명이 해당 안내서를 완성하였습니다.
Andrew Dippre
회원 가입일: 10/13/14
2,860 평판
안내서 7개 작성하였습니다
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 회원
CLEM-BENSON-F14S3G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 46
전체 시간: 32,481
