주요 콘텐츠로 건너뛰기
Dell Inspiron 15-3521 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: 1 단계, 이미지 1/3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: 1 단계, 이미지 2/3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: 1 단계, 이미지 3/3
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: 2 단계, 이미지 1/3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: 2 단계, 이미지 2/3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: 2 단계, 이미지 3/3
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: 3 단계, 이미지 1/3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: 3 단계, 이미지 2/3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: 3 단계, 이미지 3/3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Andrew Dippre
회원 가입일: 10/13/14
2,902 평판
안내서 7개 작성하였습니다
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 회원
CLEM-BENSON-F14S3G1
4 회원들
안내서 9개 작성하였습니다
댓글 한 개
Awesome post. Thanks
Derek Morgan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 45
전체 시간: 22,239
