주요 콘텐츠로 건너뛰기
Dell Inspiron 15-3521 RAM Replacement
필요한 것
  1. Dell Inspiron 15-3521 RAM Replacement, Remove the battery: 1 단계, 이미지 1/3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: 1 단계, 이미지 2/3 Dell Inspiron 15-3521 RAM Replacement, Remove the battery: 1 단계, 이미지 3/3
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 RAM Replacement, Remove access door: 2 단계, 이미지 1/3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: 2 단계, 이미지 2/3 Dell Inspiron 15-3521 RAM Replacement, Remove access door: 2 단계, 이미지 3/3
    • Loosen the two screws attaching the access door to the laptop body
    • Using a spudger, pry open the access door from the laptop
    • Using your fingers, open and remove the access door from the laptop, exposing the memory cards underneath.
  3. Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-3521 RAM Replacement, Memory Card Removal/Replacement: 3 단계, 이미지 3/3
    • To access the memory cards, push out the latches on the left and right of the memory cards
    • To remove the memory card, pull it out of the tray with the latches still stretched out
    • Insert a new memory card in to the memory card tray, depressing until side latches engage with a click.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Andrew Dippre
회원 가입일: 10/13/14
2,902 평판
안내서 7개 작성하였습니다
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 회원
CLEM-BENSON-F14S3G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 21
전체 시간: 6,226
