주요 콘텐츠로 건너뛰기
Dell Inspiron 15-3531 Motherboard Replacement
필요한 것
  1. Dell Inspiron 15-3531 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Loosen the two screws on the access panel using the PH1 head screwdriver.
    • Pry the access panel open with the spudger.
  3. Dell Inspiron 15-3531 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the memory card by pulling apart the latches holding it in place.
  4. Dell Inspiron 15-3531 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the nine 8.65mm screws holding the backplate to the laptop using the PH0 head screwdriver.
    • Remove the four 1.22 mm screws holding the backplate to the laptop using the PH0 head screwdriver.
  5. Dell Inspiron 15-3531 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard using a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting out the keyboard because there is a cable connecting it to the laptop.
  6. Dell Inspiron 15-3531 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
  7. Dell Inspiron 15-3531 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Disengage both antenna (black and white) cables by lifting them up using the spudger.
    • Unscrew the one 8.65 mm screw holding the wireless card.
    • Remove the wireless card.
  8. Dell Inspiron 15-3531 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the locking tab with the spudger and pull the cable form the locking tab.
    • Repeat with the second locking tab.
  9. Dell Inspiron 15-3531 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the four 8.65 mm screws underneath the keyboard plate.
    • Remove the three 1.22 mm small screws underneath the keyboard plate.
  10. Dell Inspiron 15-3531 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Separate the palmrest from the base of the laptop using the spudger to loosen the palmrest along the edges.
    • Make sure to remove all the screws, especially the inconspicuous 8.65 mm screw next to the hard drive.
  11. Dell Inspiron 15-3531 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron 15-3531 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the cables on the upper left side of the laptop using flat tweezers.
    • Remove the cable from the upper right hand corner.
  12. Dell Inspiron 15-3531 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Dell Inspiron 15-3531 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the speaker cable.
    • Remove cable on the right-hand side.
  13. Dell Inspiron 15-3531 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Unscrew the one 8.65 mm screw holding the motherboard in place with a PH0 size head screwdriver.
    • Remove the motherboard.
결론
작성자
4다른 기여자 명과 함께
Kody Dahlke
회원 가입일: 02/15/18
742 평판
안내서 5개를 작성함
USF Tampa, Team S1-G5, Leahy Spring 2018 USF Tampa, Team S1-G5, Leahy Spring 2018 회원
USFT-LEAHY-S18S1G5
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 34
전체 시간: 1,419
