주요 콘텐츠로 건너뛰기
Dell Inspiron 15-3543 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15-3543 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15-3543 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Brianna Blackburn
회원 가입일: 01/23/18
954 평판
안내서 4개를 작성함
댓글 한 개
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 37
전체 시간: 1,199
