주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5547 Battery Replacement
필요한 것
  1. Dell Inspiron 15-5547 Battery Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 15-5547 Battery Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 15-5547 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop on it's top and lay to a rest position.
    • Using the Phillips J0 screwdriver, remove the two indicated screws.
  2. Dell Inspiron 15-5547 Battery Replacement: 2 단계, 이미지 1/1
    • Use the spudger to carefully remove the back cover to get into the internals. Stick the spudger into the slot indicated in the photo by the marker.
    • Pry up from the slot, then pry up around the sides of the panel. The panel can then be removed by lifting the side with the slot and puling in that direction.
  3. Dell Inspiron 15-5547 Battery Replacement: 3 단계, 이미지 1/1
    • Use a Phillips J0 screwdriver in order to remove the screws indicated by the markers in the picture. It will be a total of 5 screws. Careful not to puncture the battery.
    • Carefully remove the battery by puling on the black tab.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Javier Solis
회원 가입일: 09/25/17
315 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 24
전체 시간: 2,187
