주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5547 Fan Replacement
필요한 것
  1. Dell Inspiron 15-5547 Fan Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 15-5547 Fan Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 15-5547 Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop on it's top and lay to a rest position.
    • Using the Phillips J0 screwdriver, remove the two indicated screws.
  2. Dell Inspiron 15-5547 Fan Replacement: 2 단계, 이미지 1/1
    • Use the spudger to carefully remove the back cover to get into the internals. Stick the spudger into the slot indicated in the photo by the marker.
    • Pry up from the slot, then pry up around the sides of the panel. The panel can then be removed by lifting the side with the slot and puling in that direction.
  3. Dell Inspiron 15-5547 Fan Replacement: 3 단계, 이미지 1/1
    • Use a Phillips J0 screwdriver in order to remove the screws indicated by the markers in the picture. It will be a total of 5 screws. Careful not to puncture the battery.
    • Carefully remove the battery by puling on the black tab.
  4. Dell Inspiron 15-5547 Fan Replacement, Fan: 4 단계, 이미지 1/2 Dell Inspiron 15-5547 Fan Replacement, Fan: 4 단계, 이미지 2/2
    • Start by removing the white ribbon cable. Lift up the black tab indicated by the red marker to disconnect the ribbon cable from the connector. Be careful while removing the ribbon cable, as it will possibly be taped to the fan.
  5. Dell Inspiron 15-5547 Fan Replacement: 5 단계, 이미지 1/1
    • After you have removed the ribbon cable, locate the screws indicated in the photo by the red markers (2 in total) and remove them with a Phillips J0 screwdriver.
  6. Dell Inspiron 15-5547 Fan Replacement: 6 단계, 이미지 1/1
    • Remove the fan cable, indicated by the red marker in the picture, by pulling it out from the connector. Be careful to pull it out by the plastic end instead of by the cable.
  7. Dell Inspiron 15-5547 Fan Replacement: 7 단계, 이미지 1/1
    • Once you have disconnected the fan from the motherboard, you may now remove the fan from the slot. Your laptop should now look similar to the picture in this step.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Javier Solis
회원 가입일: 09/25/17
315 평판
안내서 2개 작성하였습니다
댓글 한 개
hola tengo un problema con mi pc, porque hay un cable que se calienta mucho y no se a que se debe.
luis_gon1313 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 29
전체 시간: 1,340
