주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5547 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-5547 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip the laptop on its top so that the back is facing up as seen in the picture.
    • Using a Phillips #0 screwdriver, remove the two screws.
  2. Dell Inspiron 15-5547 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using an iFixit Opening Tool, pry open the back panel through the small notch.
  3. Dell Inspiron 15-5547 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the four screws securing the hard drive.
  4. Dell Inspiron 15-5547 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Lift the hard drive out of the dock and unplug from the motherboard.
    • Be careful so as to not damage the cable.
  5. Dell Inspiron 15-5547 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, unscrew the four screws located on the side of the chassis to free the hard drive from the bracket.
    • Remove the hard drive from the bracket.
결론
Nicholas Nafziger
회원 가입일: 11/04/19
266 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G2, Harley Fall 2019 IUPUI, Team S1-G2, Harley Fall 2019 회원
IUPUI-HARLEY-F19S1G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 1,253
