주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5547 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
    • Lift the keyboard from the top and gently detach it from the bottom end.
    • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
  2. Dell Inspiron 15-5547 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15-5547 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
    • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
    • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Faiq Huzir
회원 가입일: 05/22/19
121 평판
안내서 1개를 작성함
IUPUI, Team S1-G3, Harley Summer 2019 IUPUI, Team S1-G3, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S1G3
3 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 980
