주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5547 RAM Replacement
필요한 것
  1. Dell Inspiron 15-5547 RAM Replacement, RAM: 1 단계, 이미지 1/2 Dell Inspiron 15-5547 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Remove the two M2.5 x 5mm screws on the bottom of the laptop with the Phillips #0 screwdriver as shown.
  2. Dell Inspiron 15-5547 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-5547 RAM Replacement: 2 단계, 이미지 2/2
    • Use the Jimmy to pry off the back cover of the laptop.
    • Carefully lift and remove the back cover of the laptop.
  3. Dell Inspiron 15-5547 RAM Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-5547 RAM Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-5547 RAM Replacement: 3 단계, 이미지 3/3
    • The RAM components of the laptop can be found in the following locations.
    • Pull the two side brackets of the bottom RAM component horizontally. This will free the component.
    • Lift and remove the RAM component from its location.
    • Be careful with the RAM components as they are fragile.
  4. Dell Inspiron 15-5547 RAM Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-5547 RAM Replacement: 4 단계, 이미지 2/2
    • Repeat the previous steps for the top RAM slot.
    • Apply slight pressure onto the RAM to lock it in during the reassembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Keegan Tucker
회원 가입일: 05/22/19
256 평판
안내서 1개 작성함
IUPUI, Team S1-G3, Harley Summer 2019 IUPUI, Team S1-G3, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S1G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 843
