주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5548 RAM Replacement
필요한 것
  1. Dell Inspiron 15-5548 RAM Replacement, RAM: 1 단계, 이미지 1/3 Dell Inspiron 15-5548 RAM Replacement, RAM: 1 단계, 이미지 2/3 Dell Inspiron 15-5548 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Unplug and power off the laptop.
    • Turn the laptop over so that the grill for the fans is at the top. Locate the two screws above the grill.
    • Remove the screws with a Phillips 00 Screwdriver.
  2. Dell Inspiron 15-5548 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-5548 RAM Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to lift up on the casing and remove it from the laptop.
  3. Dell Inspiron 15-5548 RAM Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-5548 RAM Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-5548 RAM Replacement: 3 단계, 이미지 3/3
    • Locate the RAM sticks on the left side of the device.
    • On both ends of the RAM stick, pull the metal tabs away from each other.
    • The RAM stick will pop up. Gently pull the RAM stick out.
결론
Jacob Cotton
회원 가입일: 09/20/17
101 평판
안내서 1개 작성함
댓글 한 개
Hi Mr Cotton. Greetings. I have a Dell Inspiron 5548. Can I replace the present 8GB ram with 32GB in any type of DDR4 laptop ram?
Please respond to lucien395@gmail.com
Thank you
George Livingstone - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 808
