주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5552 CD-Drive Replacement
필요한 것
  1. Dell Inspiron 15-5552 CD-Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 CD-Drive Replacement: 2 단계, 이미지 1/1
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 CD-Drive Replacement: 3 단계, 이미지 1/1
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 CD-Drive Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-5552 CD-Drive Replacement: 4 단계, 이미지 2/2
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: 5 단계, 이미지 1/2 Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: 5 단계, 이미지 2/2
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 CD-Drive Replacement: 6 단계, 이미지 1/2 Dell Inspiron 15-5552 CD-Drive Replacement: 6 단계, 이미지 2/2
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 CD-Drive Replacement: 7 단계, 이미지 1/1
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 CD-Drive Replacement: 8 단계, 이미지 1/2 Dell Inspiron 15-5552 CD-Drive Replacement: 8 단계, 이미지 2/2
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  9. Dell Inspiron 15-5552 CD-Drive Replacement, CD-Drive: 9 단계, 이미지 1/1
    • CD-Drive
    • Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
  10. Dell Inspiron 15-5552 CD-Drive Replacement: 10 단계, 이미지 1/1
    • Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
  11. Dell Inspiron 15-5552 CD-Drive Replacement: 11 단계, 이미지 1/2 Dell Inspiron 15-5552 CD-Drive Replacement: 11 단계, 이미지 2/2
    • After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chandler Champion
회원 가입일: 01/23/18
364 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 166
