주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5552 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-5552 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 2개
    • Use a JIS #0 screwdriver to unscrew the two 6 mm screws from the back panel.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  6. Dell Inspiron 15-5552 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Using a spudger, lightly lift the RAM cover up and at an angle, away from the computer.
  7. Dell Inspiron 15-5552 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 6 mm JIS #0 screws from the hard drive.
  8. Dell Inspiron 15-5552 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Lift hard drive out of the computer slightly.
    • Be careful not to tear the ribbon that attaches the hard drive to the computer when lifting it.
  9. Dell Inspiron 15-5552 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Using two fingers, grab the black connector on the ribbon, and pull until detached.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Mitchell Roberts
회원 가입일: 01/23/18
321 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 447
