주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5552 Memory Replacement
필요한 것
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Memory Replacement: 4 단계, 이미지 2개 중 2개
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: 5 단계, 이미지 1개 중 1개
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: 6 단계, 이미지 1개 중 1개
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 7 단계, 이미지 3개 중 1개 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 7 단계, 이미지 3개 중 2개 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: 7 단계, 이미지 3개 중 3개
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: 8 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: 8 단계, 이미지 2개 중 2개
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: 9 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: 9 단계, 이미지 2개 중 2개
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
결론
작성자
4다른 기여자 명과 함께
Chandler Champion
회원 가입일: 01/23/18
364 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 20
전체 시간: 323
