주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5558 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Antenna Cable: 1 단계, 이미지 1개 중 1개
  2. Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15-5558 Display Assembly Replacement, Disconnecting the Display Cable: 2 단계, 이미지 2개 중 2개
    • Lift the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15-5558 Display Assembly Replacement, Note the Display Cable: 3 단계, 이미지 1개 중 1개
    • Note the display cable routing and remove the cable from its routing guides.
  4. Dell Inspiron 15-5558 Display Assembly Replacement, Turn the Computer Over: 4 단계, 이미지 1개 중 1개
    • Turn the computer over.
    • Open the display at an angle of 90 degrees.
  5. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Computer: 5 단계, 이미지 1개 중 1개
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  6. Dell Inspiron 15-5558 Display Assembly Replacement, Remove the Screws: 6 단계, 이미지 1개 중 1개
    • Remove the screws that secure the display hinges to the palm-rest assembly.
  7. Dell Inspiron 15-5558 Display Assembly Replacement, Lifting the Display Assembly: 7 단계, 이미지 1개 중 1개
    • Lift the display assembly off the palm-rest assembly.
  8. Dell Inspiron 15-5558 Display Assembly Replacement, Placing the Palm Rest Assembly: 8 단계, 이미지 1개 중 1개
    • Place the palm-rest assembly at the edge of the table with the coin-cell battery facing away from the edge.
  9. Dell Inspiron 15-5558 Display Assembly Replacement, Align the Screw Holes: 9 단계, 이미지 1개 중 1개
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 15-5558 Display Assembly Replacement, Replace the Screws: 10 단계, 이미지 1개 중 1개
    • Replace the screws that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 15-5558 Display Assembly Replacement, Route the Display Cable: 11 단계, 이미지 1개 중 1개
    • Close the display and turn the computer over.
    • Route the display cable through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 15-5558 Display Assembly Replacement, Slide the Display Cable: 12 단계, 이미지 1개 중 1개
    • Slide the display cable to the connector and press down on the latch to connect the display cable to the system board.
  13. Dell Inspiron 15-5558 Display Assembly Replacement, Routing the Antenna Cable: 13 단계, 이미지 1개 중 1개
    • Route the antenna cable through the routing guides on the palm-rest assembly.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,522 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 14
전체 시간: 1,991
