주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5558 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15-5558 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 1개 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 2개 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 15-5558 Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 15-5558 Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Adam Lourenco
회원 가입일: 10/19/17
793 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G4
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 45
전체 시간: 4,932
