소개
If your device screen breaks, you might need to replace it. The screen is the part of the device when images are displayed. This guide shows you how to replace a broken or faulty screen
필요한 것
Open device so it is at least opened at a 90 degree angle.
Wedge a spudger between the screen and the plastic frame.
Push in the spudger and push down to pop the frame from the pins.
Repeat around the whole frame.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
How many pins is the screen connector? 30? 40?
Very useful guide. Works with Dell Inspiron 15 5559. Screen replacement is a lot easier than replacing the whole screen assembly.
