주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5559 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15-5559 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 1개 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 2개 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 3개
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15-5559 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kyla Ward
회원 가입일: 03/19/18
649 평판
안내서 4개를 작성함
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G5
3 회원들
안내서 5개를 작성함
댓글 2개
The blue part came off is that important?
walterandradeconde - 답글
can i put this in a harddrive enclosure?
chiggly 123 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 24
전체 시간: 5,466
