주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5559 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15-5559 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Dell Inspiron 15-5559 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Dell Inspiron 15-5559 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Use the metal spudger to pry the keyboard off. Do this by inserting the spudger into each of the five indicated slots at the top of the keyboard and gently pulling up on the keyboard with the spudger. Do not be afraid to use a bit of muscle to remove the keyboard, as it takes a bit of force to remove
  2. Dell Inspiron 15-5559 Keyboard Replacement: 2 단계, 이미지 1/1
    • Once you have pried the keyboard off with the spudger, lift the keyboard upward with you hands.
    • It is important to note that the keyboard is still attached to the device with two flat connective cables. It is important that you gently remove the keyboard to prevent damaging the cables.
  3. Dell Inspiron 15-5559 Keyboard Replacement: 3 단계, 이미지 1/2 Dell Inspiron 15-5559 Keyboard Replacement: 3 단계, 이미지 2/2
    • Once the keyboard has been lifted you will notice two conductive tape cables. one large and one small.
  4. Dell Inspiron 15-5559 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-5559 Keyboard Replacement: 4 단계, 이미지 2/2
    • Disconnect the smaller of the two flat conductive tape cables.
    • Place a metal spudger on the end of the cable that is connected to the laptop and use it to lift the black clasp holding the tape down, then pull the cable out toward the right. Repeat for the second larger piece of conductive tape.
    • You should remove this flat connective cable with care to prevent damaging it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Martin Lechuga
회원 가입일: 03/18/18
171 평판
안내서 1개 작성함
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 46
전체 시간: 2,966
