소개
Before you attempt this guide make sure your device is not connected to a power source and be sure that the battery is removed. This guide is relatively easy and doesn't require any special skills.
필요한 것
Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
거의 끝나갑니다!
결론
