주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5565 Battery Replacement
필요한 것
  1. Dell Inspiron 15-5565 Battery Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15-5565 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15-5565 Battery Replacement: 2 단계, 이미지 3/3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Battery Replacement, Back Cover: 3 단계, 이미지 1/2 Dell Inspiron 15-5565 Battery Replacement, Back Cover: 3 단계, 이미지 2/2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 15-5565 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Battery Replacement, Battery: 5 단계, 이미지 1/2 Dell Inspiron 15-5565 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the three 5 mm screws from the battery bracket using a Phillips #00 screwdriver.
  6. Dell Inspiron 15-5565 Battery Replacement: 6 단계, 이미지 1/3 Dell Inspiron 15-5565 Battery Replacement: 6 단계, 이미지 2/3 Dell Inspiron 15-5565 Battery Replacement: 6 단계, 이미지 3/3
    • Remove the five 5 mm screws from the outer edges of the battery using a Phillips #00 screwdriver.
    • Remove the battery from the laptop.
결론
Avery Wasylyszyn
회원 가입일: 03/08/23
228 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 283
